Ir para o conteúdo principal
Nabi 2 Screen Replacement
O que você precisa
    1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: passo 1, imagem 1 %32 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: passo 1, imagem 2 %32 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: passo 1, imagem 3 %32
      • Remove the rubber bumper from the tablet.
      Pergunte ao FixBot
      Comentar
    2. Nabi 2  Screen Replacement: passo 2, imagem 1 %32 Nabi 2  Screen Replacement: passo 2, imagem 2 %32
      • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
      Pergunte ao FixBot
      Comentar
    3. Nabi 2  Screen Replacement: passo 3, imagem 1 %32 Nabi 2  Screen Replacement: passo 3, imagem 2 %32 Nabi 2  Screen Replacement: passo 3, imagem 3 %32
      • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
      • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
      • Do not force the clips open, as they are fairly easy to break
      Pergunte ao FixBot
      Comentar
    1. Nabi 2  Screen Replacement, Screen: passo 4, imagem 1 %32 Nabi 2  Screen Replacement, Screen: passo 4, imagem 2 %32 Nabi 2  Screen Replacement, Screen: passo 4, imagem 3 %32
      • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
      Pergunte ao FixBot
      Comentar
    2. Nabi 2  Screen Replacement: passo 5, imagem 1 %32 Nabi 2  Screen Replacement: passo 5, imagem 2 %32 Nabi 2  Screen Replacement: passo 5, imagem 3 %32
      • Using a spudger, slide the brown tab forward on each side of the connector
      • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
      • If the screen is not working correctly, you will need to replace the entire display assembly
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Michelle
Membro desde: 02/09/16
899 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 4-3, Lacy Spring 2016 Membro de USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Membros
Autoria de 14 guias
4Comentários do guia
Simple steps but very practical
myjamro - Responder Compartilhar
Is the LCD glued to the front glass/digitizer?
Brent Huff - Responder Compartilhar
It Worked Thank U So Much!!!
Sharon Thrash - Responder Compartilhar
a piece that holds the screen ribbon cable in broke off my nabis motherboard while taking the screen off. I eventually did get the screen back on.
NabiGuy - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 47
Ao todo: 8,569
