Ir para o conteúdo principal
NP-R540-JA09US Keyboard Replacement
O que você precisa
  1. NP-R540-JA09US Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
    Pergunte ao FixBot
    Comentar
  2. NP-R540-JA09US Keyboard Replacement: passo 2, imagem 1 %32
    • Pull the two latches outward.
    Pergunte ao FixBot
    Comentar
  3. NP-R540-JA09US Keyboard Replacement: passo 3, imagem 1 %32 NP-R540-JA09US Keyboard Replacement: passo 3, imagem 2 %32
    • Slide the battery out of the laptop.
    Pergunte ao FixBot
    Comentar
  4. NP-R540-JA09US Keyboard Replacement, Optical Drive: passo 4, imagem 1 %32
    • Remove securing screw with the PH0 head.
    Pergunte ao FixBot
    Comentar
  5. NP-R540-JA09US Keyboard Replacement: passo 5, imagem 1 %32
    • Slide the optical drive out and remove it from the device.
    Pergunte ao FixBot
    Comentar
  6. NP-R540-JA09US Keyboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Remove the two Phillips #0 screws labeled KBD.
    Pergunte ao FixBot
    Comentar
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
    Pergunte ao FixBot
    Comentar
  7. NP-R540-JA09US Keyboard Replacement: passo 8, imagem 1 %32
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
    Pergunte ao FixBot
    Comentar
  8. NP-R540-JA09US Keyboard Replacement: passo 9, imagem 1 %32 NP-R540-JA09US Keyboard Replacement: passo 9, imagem 2 %32
    • Disconnect the keyboard cable from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 1,346
