Ir para o conteúdo principal
NETGEAR WGT624 v3 Reset Button Replacement
O que você precisa
  1. NETGEAR WGT624 v3 Reset Button Replacement, Lower Case: passo 1, imagem 1 %32
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Reset Button Replacement: passo 2, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 2, imagem 2 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Reset Button Replacement: passo 3, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 3, imagem 2 %32
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Reset Button Replacement: passo 4, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 4, imagem 2 %32
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Reset Button Replacement, Motherboard: passo 5, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement, Motherboard: passo 5, imagem 2 %32
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Reset Button Replacement: passo 6, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 6, imagem 2 %32
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Reset Button Replacement, Antenna: passo 7, imagem 1 %32
    • Turn the motherboard, so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Reset Button Replacement: passo 8, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 8, imagem 2 %32
    • Remove the yellow tape that holds the wire.
    • Make sure that you set the tape aside on a clean surface, so that it can be reused.
  9. NETGEAR WGT624 v3 Reset Button Replacement: passo 9, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 9, imagem 2 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
    • The wire should now be completely separate from the motherboard.
  10. NETGEAR WGT624 v3 Reset Button Replacement: passo 10, imagem 1 %32
    • Extend the antenna away from the device, so that it becomes straight.
  11. NETGEAR WGT624 v3 Reset Button Replacement: passo 11, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 11, imagem 2 %32 NETGEAR WGT624 v3 Reset Button Replacement: passo 11, imagem 3 %32
    • Find the clips that hold the antenna onto the router.
    • Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
    • The antenna may take considerable force to remove.
  12. NETGEAR WGT624 v3 Reset Button Replacement: passo 12, imagem 1 %32
    • Completely separate the antenna and wire from the rest of the device.
  13. NETGEAR WGT624 v3 Reset Button Replacement, Reset Button: passo 13, imagem 1 %32 NETGEAR WGT624 v3 Reset Button Replacement, Reset Button: passo 13, imagem 2 %32
    • Remove the metal frame.
  14. NETGEAR WGT624 v3 Reset Button Replacement: passo 14, imagem 1 %32
    • Turn over the motherboard.
  15. NETGEAR WGT624 v3 Reset Button Replacement: passo 15, imagem 1 %32
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the four connections between the reset button and the motherboard
    • For proper soldering and desoldering techniques, refer here.
    • Pull the reset button from the other side of the mother board once the solder is liquid.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathon Sather
Membro desde: 01/23/13
45 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-31, Amido Winter 2013 Membro de Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 790
