Introdução
Is the screen cracked or non responsive then replacing it will fix the NABI XD.
O que você precisa
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the two 4mm Phillips screws with the PH#0 screwdriver.
Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
The ribbons are glued to the frame so gently lift them up without ripping them.
Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
Remove five 4mm Phillips screws from the frame.
Uma outra pessoa concluiu este guia.
1Comentário do guia
Will the screen from an A or C model work with a B model?
