Introdução
Has the battery been damaged or the device won't charge. Changing the battery may fix these problems.
O que você precisa
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
