Ir para o conteúdo principal
Munchkinz Motherboard Replacement
O que você precisa
    1. Munchkinz Motherboard Replacement, Opening Device: passo 1, imagem 1 %32
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      Pergunte ao FixBot
      Comentar
    2. Munchkinz Motherboard Replacement, Pry Device Apart: passo 2, imagem 1 %32 Munchkinz Motherboard Replacement, Pry Device Apart: passo 2, imagem 2 %32
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      Pergunte ao FixBot
      Comentar
    3. Munchkinz Motherboard Replacement, Separated Device: passo 3, imagem 1 %32
      • After prying the device apart, it should look like this.
      Pergunte ao FixBot
      Comentar
    1. Munchkinz Motherboard Replacement, Pry Camera: passo 4, imagem 1 %32
      • Use the slim plastic opening tool to pry the camera from its initial position.
      Pergunte ao FixBot
      Comentar
    2. Munchkinz Motherboard Replacement, Disconnect Ribbon: passo 5, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Munchkinz Motherboard Replacement, Pry Speaker: passo 6, imagem 1 %32 Munchkinz Motherboard Replacement, Pry Speaker: passo 6, imagem 2 %32
      • Use the slim plastic opening tool to remove the speaker from its position on the case.
      Pergunte ao FixBot
      Comentar
    2. Munchkinz Motherboard Replacement, Locate Wires: passo 7, imagem 1 %32
      • Locate the red and black wires that connect the speaker to the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Munchkinz Motherboard Replacement, Solder Wires: passo 8, imagem 1 %32
      • Un-solder the red and black speaker wires that are connected to the motherboard
      Pergunte ao FixBot
      Comentar
    1. Munchkinz Motherboard Replacement, Volume Button: passo 9, imagem 1 %32
      • Remove the plastic volume button.
      Pergunte ao FixBot
      Comentar
    2. Munchkinz Motherboard Replacement, Unscrew Module: passo 10, imagem 1 %32
      • Remove the two screws that hold the volume button assembly in place.
      Pergunte ao FixBot
      Comentar
    3. Munchkinz Motherboard Replacement, Solder Module Wires: passo 11, imagem 1 %32
      • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
      Pergunte ao FixBot
      Comentar
    1. Munchkinz Motherboard Replacement, Removing battery: passo 12, imagem 1 %32 Munchkinz Motherboard Replacement, Removing battery: passo 12, imagem 2 %32 Munchkinz Motherboard Replacement, Removing battery: passo 12, imagem 3 %32
      • Use the wide plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      Pergunte ao FixBot
      Comentar
    2. Munchkinz Motherboard Replacement, Remove battery completely: passo 13, imagem 1 %32
      • Use the Soldering Iron to disconnect the each cable.
      Pergunte ao FixBot
      Comentar
    1. Munchkinz Motherboard Replacement, Remove Tape: passo 14, imagem 1 %32
      • Remove black tape covering any of the ribbons that have it.
      Pergunte ao FixBot
      Comentar
    2. Munchkinz Motherboard Replacement, Remove Ribbons: passo 15, imagem 1 %32
      • Pull the ribbons out from the plugs.
      Pergunte ao FixBot
      Comentar
    3. Munchkinz Motherboard Replacement, Remove Camera/Hidden Screw: passo 16, imagem 1 %32
      • After removing the camera, remove the hidden screw.
      Pergunte ao FixBot
      Comentar
    4. Munchkinz Motherboard Replacement, Remove Screws: passo 17, imagem 1 %32
      • Remove screws located on the opposite side of the battery.
      Pergunte ao FixBot
      Comentar
    5. Munchkinz Motherboard Replacement, Lift: passo 18, imagem 1 %32
      • Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UW Tacoma, Team 3-6, Rose Winter 2015 Membro de UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 523
