Ir para o conteúdo principal
Munchkinz LCD Assembly
O que você precisa
  1. Munchkinz LCD Assembly, Opening Device: passo 1, imagem 1 %32
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
    Pergunte ao FixBot
    Comentar
  2. Munchkinz LCD Assembly, Pry Device Apart: passo 2, imagem 1 %32 Munchkinz LCD Assembly, Pry Device Apart: passo 2, imagem 2 %32
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
    Pergunte ao FixBot
    Comentar
  3. Munchkinz LCD Assembly, Separated Device: passo 3, imagem 1 %32
    • After prying the device apart, it should look like this.
    Pergunte ao FixBot
    Comentar
  4. Munchkinz LCD Assembly, Remove Speaker: passo 4, imagem 1 %32
    • Use the plastic opening tool to remove the speaker from the casing.
    Pergunte ao FixBot
    Comentar
  5. Munchkinz LCD Assembly, Pry Camera: passo 5, imagem 1 %32
    • Use the slim plastic opening tool to pry the camera from its position.
    Pergunte ao FixBot
    Comentar
  6. Munchkinz LCD Assembly, Unscrew Volume Module: passo 6, imagem 1 %32 Munchkinz LCD Assembly, Unscrew Volume Module: passo 6, imagem 2 %32
    • Unscrew the two screws that hold the volume module to the casing.
    Pergunte ao FixBot
    Comentar
  7. Munchkinz LCD Assembly, Pry Battery: passo 7, imagem 1 %32
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
    Pergunte ao FixBot
    Comentar
  8. Munchkinz LCD Assembly, Remove Ribbons: passo 8, imagem 1 %32
    • Remove the two highlighted ribbons from the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Munchkinz LCD Assembly, Remove Screws: passo 9, imagem 1 %32
    • Use the screw driver to remove the highlighted screws.
    Pergunte ao FixBot
    Comentar
  10. Munchkinz LCD Assembly, Remove Hidden Screw: passo 10, imagem 1 %32
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
    Pergunte ao FixBot
    Comentar
  11. Munchkinz LCD Assembly, Remove Motherboard: passo 11, imagem 1 %32
    • Remove the motherboard from the casing.
    Pergunte ao FixBot
    Comentar
  12. Munchkinz LCD Assembly, Pry Up Screen: passo 12, imagem 1 %32 Munchkinz LCD Assembly, Pry Up Screen: passo 12, imagem 2 %32 Munchkinz LCD Assembly, Pry Up Screen: passo 12, imagem 3 %32
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
    Pergunte ao FixBot
    Comentar
  13. Munchkinz LCD Assembly, Solder LCD Wires: passo 13, imagem 1 %32
    • Unsolder the black and red LCD wires.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
David Wood
Membro desde: 02/05/15
440 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team 3-6, Rose Winter 2015 Membro de UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 32
Ao todo: 631
