Ir para o conteúdo principal
Munchkin Mozart Magic Cube Light Replacement
O que você precisa
  1. Munchkin Mozart Magic Cube Light Replacement, Face plate: passo 1, imagem 1 %32 Munchkin Mozart Magic Cube Light Replacement, Face plate: passo 1, imagem 2 %32
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Light Replacement: passo 2, imagem 1 %32
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Light Replacement: passo 3, imagem 1 %32
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Light Replacement: passo 4, imagem 1 %32
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Light Replacement: passo 5, imagem 1 %32
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Light Replacement: passo 6, imagem 1 %32
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Light Replacement: passo 7, imagem 1 %32
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Light Replacement, Frame Removal: passo 8, imagem 1 %32
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
  9. Munchkin Mozart Magic Cube Light Replacement, Light: passo 9, imagem 1 %32
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
    • Use the Jimmy to remove the glue connecting the motherboard to the white frame.
  10. Munchkin Mozart Magic Cube Light Replacement: passo 10, imagem 1 %32
    • Slide the motherboard out of the frame.
  11. Munchkin Mozart Magic Cube Light Replacement: passo 11, imagem 1 %32
    • Use the soldering iron to desolder the LED by applying heat to the half sphere like connections.
    • For soldering instructions please see this additional guide Como soldar e dessoldar contatos
  12. Munchkin Mozart Magic Cube Light Replacement: passo 12, imagem 1 %32
    • Take the new LED and solder the two legs back to the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 1-4, Sullivan Fall 2015 Membro de USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 489
