Ir para o conteúdo principal
Mpow MPBH063 Battery Replacement
O que você precisa
  1. Mpow MPBH063 Battery Replacement, Battery: passo 1, imagem 1 %32 Mpow MPBH063 Battery Replacement, Battery: passo 1, imagem 2 %32 Mpow MPBH063 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
    Pergunte ao FixBot
    Comentar
  2. Mpow MPBH063 Battery Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
    Pergunte ao FixBot
    Comentar
  3. Mpow MPBH063 Battery Replacement: passo 3, imagem 1 %32
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Mpow MPBH063 Battery Replacement: passo 4, imagem 1 %32
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
Lianna Cook
Membro desde: 10/09/18
272 Reputação
Autoria de 2 guias
2Comentários do guia
Where can I find a replacement battery for this speaker?
Sean DuBois - Responder Compartilhar
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 4,781
