Ir para o conteúdo principal
Mpow 059 Battery Replacement
O que você precisa
  1. Mpow 059 Battery  Replacement, Ear Cushion: passo 1, imagem 1 %32 Mpow 059 Battery  Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
    Pergunte ao FixBot
    Comentar
  2. Mpow 059 Battery  Replacement: passo 2, imagem 1 %32
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
    Pergunte ao FixBot
    Comentar
  3. Mpow 059 Battery  Replacement, Battery: passo 3, imagem 1 %32 Mpow 059 Battery  Replacement, Battery: passo 3, imagem 2 %32
    • Use the Phillips #1 screwdriver to remove the six screws holding the red plastic cover in place.
    • Carefully peel the plastic cover off the left cup to reveal the ear cup's internal components.
    • There is some adhesive holding the red cover down so be careful as you remove it so it doesn't break or crack.
    Pergunte ao FixBot
    Comentar
  4. Mpow 059 Battery  Replacement: passo 4, imagem 1 %32
    • Use the JIS J00 screwdriver to remove the 3 screws that secure the black cover.
    Pergunte ao FixBot
    Comentar
  5. Mpow 059 Battery  Replacement: passo 5, imagem 1 %32
    • Remove the black cover to reveal the battery. The battery is attached to the back of the black cover.
    • The plastic cover of the headphones is connected to the battery housing by a wire connector. Be careful not to harm this cable by pulling the cap too hard during disassembly.
    • Undo the cable and remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Equipe
8Comentários do guia
Hello
What kind of glue should I use to put new pad?
Martin Dromigny - Responder Compartilhar
What is the part number for the replacement battery? Where can I find one?
hdm_1@comcast.net - Responder Compartilhar
Battery is a 503030 3.7v 420mAh
Mark Jobe - Responder Compartilhar
First, you need to pry the piece behind the R headphone, which is itself adhered. THEN you need to pry the battery off of the backing.
And finally, you can realize you did all of this for nothing if you don't know how to solder. The battery cables are soldered onto the chip, making it impossible to replace without soldering in the replacement wires.
biggles1701 bob - Responder Compartilhar
This is good to know. I was thinking there was something missing as to how the battery is connected. While I'd like to save my headphones from the landfill, it looks like a case of planned obsolescence. Guess I'll be hunting for new headphones with better repair-ability
Nell - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 97
Ao todo: 8,311
