Ir para o conteúdo principal
Motorola i710 Keypad Cover Replacement
O que você precisa
  1. Motorola i710 Keypad Cover Replacement, Battery Cover: passo 1, imagem 1 %32 Motorola i710 Keypad Cover Replacement, Battery Cover: passo 1, imagem 2 %32
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    Pergunte ao FixBot
    Comentar
  2. Motorola i710 Keypad Cover Replacement, Battery: passo 2, imagem 1 %32
    • Push the battery towards the top of the phone and lift up.
    Pergunte ao FixBot
    Comentar
  3. Motorola i710 Keypad Cover Replacement, Back Casing: passo 3, imagem 1 %32 Motorola i710 Keypad Cover Replacement, Back Casing: passo 3, imagem 2 %32 Motorola i710 Keypad Cover Replacement, Back Casing: passo 3, imagem 3 %32
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    Pergunte ao FixBot
    Comentar
  4. Motorola i710 Keypad Cover Replacement, Motherboard: passo 4, imagem 1 %32 Motorola i710 Keypad Cover Replacement, Motherboard: passo 4, imagem 2 %32 Motorola i710 Keypad Cover Replacement, Motherboard: passo 4, imagem 3 %32
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola i710 Keypad Cover Replacement, Keypad Sensor: passo 5, imagem 1 %32 Motorola i710 Keypad Cover Replacement, Keypad Sensor: passo 5, imagem 2 %32
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
    Pergunte ao FixBot
    Comentar
  6. Motorola i710 Keypad Cover Replacement, Keypad Cover: passo 6, imagem 1 %32 Motorola i710 Keypad Cover Replacement, Keypad Cover: passo 6, imagem 2 %32
    • Once the keypad has been removed, the keypad cover can be easily peeled back from the front phone cover molding.
    • Care must be taken when inserting a new keypad cover. The keypad cover will have to be lined up to the corresponding holes of the phone casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Katelyn
Membro desde: 10/22/12
1 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 14-2, Benson Fall 2012 Membro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 43
Ao todo: 717
