Ir para o conteúdo principal
Motorola V557 Keypad Replacement
O que você precisa
  1. Motorola V557 Keypad Replacement, Battery: passo 1, imagem 1 %32 Motorola V557 Keypad Replacement, Battery: passo 1, imagem 2 %32 Motorola V557 Keypad Replacement, Battery: passo 1, imagem 3 %32
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
    Pergunte ao FixBot
    Comentar
  2. Motorola V557 Keypad Replacement: passo 2, imagem 1 %32 Motorola V557 Keypad Replacement: passo 2, imagem 2 %32
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Motorola V557 Keypad Replacement, SIM Card: passo 3, imagem 1 %32 Motorola V557 Keypad Replacement, SIM Card: passo 3, imagem 2 %32 Motorola V557 Keypad Replacement, SIM Card: passo 3, imagem 3 %32
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
    Pergunte ao FixBot
    Comentar
  4. Motorola V557 Keypad Replacement, Antenna: passo 4, imagem 1 %32 Motorola V557 Keypad Replacement, Antenna: passo 4, imagem 2 %32
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
    Pergunte ao FixBot
    Comentar
  5. Motorola V557 Keypad Replacement, Rear Casing: passo 5, imagem 1 %32 Motorola V557 Keypad Replacement, Rear Casing: passo 5, imagem 2 %32 Motorola V557 Keypad Replacement, Rear Casing: passo 5, imagem 3 %32
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
    Pergunte ao FixBot
    Comentar
  6. Motorola V557 Keypad Replacement: passo 6, imagem 1 %32 Motorola V557 Keypad Replacement: passo 6, imagem 2 %32 Motorola V557 Keypad Replacement: passo 6, imagem 3 %32
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Motorola V557 Keypad Replacement: passo 7, imagem 1 %32 Motorola V557 Keypad Replacement: passo 7, imagem 2 %32 Motorola V557 Keypad Replacement: passo 7, imagem 3 %32
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
    Pergunte ao FixBot
    Comentar
  8. Motorola V557 Keypad Replacement, Motherboard: passo 8, imagem 1 %32 Motorola V557 Keypad Replacement, Motherboard: passo 8, imagem 2 %32 Motorola V557 Keypad Replacement, Motherboard: passo 8, imagem 3 %32
    • Separate the front ribbon cable from the board with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  9. Motorola V557 Keypad Replacement: passo 9, imagem 1 %32 Motorola V557 Keypad Replacement: passo 9, imagem 2 %32 Motorola V557 Keypad Replacement: passo 9, imagem 3 %32
    • Make sure you don’t break the ribbon cables that attach to the side buttons when removing the motherboard.
    • Lift out the motherboard only after all cables have been disconnected. Try to touch it only from the sides.
    Pergunte ao FixBot
    Comentar
  10. Motorola V557 Keypad Replacement, Keypad: passo 10, imagem 1 %32 Motorola V557 Keypad Replacement, Keypad: passo 10, imagem 2 %32 Motorola V557 Keypad Replacement, Keypad: passo 10, imagem 3 %32
    • With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Chad Brantley
Membro desde: 10/06/10
32 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-50, Amido Fall 2010 Membro de Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 1,315
