Ir para o conteúdo principal
Motorola V276 Small LCD Display Screen Replacement
O que você precisa
  1. Motorola V276 Small LCD Display Screen Replacement, Front panel/ Screen Logic Board: passo 1, imagem 1 %32
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
    Pergunte ao FixBot
    Comentar
  2. Motorola V276 Small LCD Display Screen Replacement: passo 2, imagem 1 %32
    • Using the T6 Torx Screwdriver remove all 4 small screws.
    Pergunte ao FixBot
    Comentar
  3. Motorola V276 Small LCD Display Screen Replacement: passo 3, imagem 1 %32
    • Remove silver plate from phone.
    Pergunte ao FixBot
    Comentar
  4. Motorola V276 Small LCD Display Screen Replacement: passo 4, imagem 1 %32
    • Using the spudger remove the plastic camera casing
    Pergunte ao FixBot
    Comentar
  5. Motorola V276 Small LCD Display Screen Replacement: passo 5, imagem 1 %32
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
    Pergunte ao FixBot
    Comentar
  6. Motorola V276 Small LCD Display Screen Replacement: passo 6, imagem 1 %32
    • Use Spudger or hands to detach flex cable from front screen logic board
    Pergunte ao FixBot
    Comentar
  7. Motorola V276 Small LCD Display Screen Replacement, Small LCD Display Screen: passo 7, imagem 1 %32
    • Use a plastic opening tool to lift the small black flap to unlock the screen from the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Motorola V276 Small LCD Display Screen Replacement: passo 8, imagem 1 %32
    • Using your fingers, carefully pull out the small LCD display screen.
    Pergunte ao FixBot
    Comentar
  9. Motorola V276 Small LCD Display Screen Replacement: passo 9, imagem 1 %32
    • Remove the small LCD display screen completely from the green logic board.
    Pergunte ao FixBot
    Comentar
Conclusão
Cecilia
Membro desde: 04/11/10
1 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 27-96, Amido Spring 2010 Membro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 42
Ao todo: 2,983
