Ir para o conteúdo principal
Motorola V276 Battery Replacement
O que você precisa
  1. Motorola V276 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    Pergunte ao FixBot
    Comentar
  2. Motorola V276 Battery Replacement: passo 2, imagem 1 %32
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Motorola V276 Battery Replacement: passo 3, imagem 1 %32 Motorola V276 Battery Replacement: passo 3, imagem 2 %32
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 27-96, Amido Spring 2010 Membro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 46
Ao todo: 2,028
