Ir para o conteúdo principal
Motorola Razr+ Screen Protector Replacement
O que você precisa
  1. Motorola Razr+ Screen Protector Replacement, Alignment adapter information: passo 1, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Alignment adapter information: passo 1, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Alignment adapter information: passo 1, imagem 3 %32
    • Before starting your repair, familiarize yourself with the different parts of the alignment adapter:
    • The top of the adapter has a spring‑loaded adjuster and hooks that align the screen protector.
    • The bottom of the adapter has a charging port holder (held in place by a screw) and alignment posts for the screen protector.
  2. Motorola Razr+ Screen Protector Replacement, Loosen the charging port holder screw: passo 2, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Loosen the charging port holder screw: passo 2, imagem 2 %32
    • Use a 2.5 mm hex screwdriver to loosen (not remove) the screw securing the charging port holder.
  3. Motorola Razr+ Screen Protector Replacement, Slide the charging port holder into place: passo 3, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Slide the charging port holder into place: passo 3, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Slide the charging port holder into place: passo 3, imagem 3 %32
    • Completely open your phone and unplug any cables.
    • Place the phone in the alignment adapter so the charging port is near its holder on the bottom edge.
    • With one hand, lift the charging port holder until it's aligned with the port.
    • With your free hand, push the phone so the holder goes into the port.
  4. Motorola Razr+ Screen Protector Replacement, Secure the phone with the top adjuster: passo 4, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Secure the phone with the top adjuster: passo 4, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Secure the phone with the top adjuster: passo 4, imagem 3 %32
    • With one hand, hold the bottom of the phone in place so the port holder doesn't slide out.
    • With your free hand, pull the spring‑loaded adjuster on the top of the adapter until the phone drops into place.
    • Check the top and bottom edges of the phone to ensure it's fully seated in the alignment adapter.
  5. Motorola Razr+ Screen Protector Replacement, Tighten the charging port holder screw: passo 5, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Tighten the charging port holder screw: passo 5, imagem 2 %32
    • Use a 2.5 mm hex screwdriver to tighten the screw securing the charging port holder.
  6. Motorola Razr+ Screen Protector Replacement, Create a shim: passo 6, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Create a shim: passo 6, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Create a shim: passo 6, imagem 3 %32
    • In this step, you'll create a shim to separate the old screen protector from your phone's screen.
    • Use scissors to cut a small square (about the size of your thumbnail) out of your replacement screen protector liner, just between the two long cutouts on the bottom edge.
  7. Motorola Razr+ Screen Protector Replacement, Separate the screen protector from the screen: passo 7, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Separate the screen protector from the screen: passo 7, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Separate the screen protector from the screen: passo 7, imagem 3 %32
    • Slide the sharpest corner of your shim under one of the top corners of your screen protector.
    • It might take a few tries to separate the protector from the screen. If it feels stubborn, cut a new edge on your shim and try again.
  8. Motorola Razr+ Screen Protector Replacement, Grip the screen protector: passo 8, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Grip the screen protector: passo 8, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Grip the screen protector: passo 8, imagem 3 %32
    • Insert your shim deeper under the corner of the protector until you can grip it with your fingers.
  9. Motorola Razr+ Screen Protector Replacement, Remove the screen protector: passo 9, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Remove the screen protector: passo 9, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Remove the screen protector: passo 9, imagem 3 %32
    • Peel and remove the old screen protector.
  10. Motorola Razr+ Screen Protector Replacement, Prepare your workspace: passo 10, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Prepare your workspace: passo 10, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Prepare your workspace: passo 10, imagem 3 %32
    • Have your replacement screen protector and roller within reach—you'll be holding the protector up with one hand and won't be able to let go to reposition or grab a tool.
    • Orient the replacement protector so that the oval cutout is on the top right, and the long cutouts are toward the bottom of the phone.
  11. Motorola Razr+ Screen Protector Replacement, Clean your screen: passo 11, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Clean your screen: passo 11, imagem 2 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to your screen.
    • Use a microfiber or lint free cloth to wipe away any smudges or dust.
  12. Motorola Razr+ Screen Protector Replacement, Remove the protective liner: passo 12, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Remove the protective liner: passo 12, imagem 2 %32
    • Hold the replacement screen protector with its liner pull tab facing down. Keep the film facing down to prevent dust from settling onto the sticky side.
    • Peel and fully remove the protective liner from the underside of the protector.
    • During the next two steps, don't set the protector down or wait for an extended period of time—as soon as the adhesive is exposed, it'll slowly attract dust.
  13. Motorola Razr+ Screen Protector Replacement, Align the screen protector: passo 13, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Align the screen protector: passo 13, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Align the screen protector: passo 13, imagem 3 %32
    • Make sure no dust settled on your phone's screen since you cleaned it. Any dust or smudges will prevent the protector from adhering. If dust does settle, lift the protector slightly and wipe the screen down again.
    • Slide the top circle and oval cutouts over the hooks on the upper alignment posts.
    • Gently pull the replacement protector over the screen and onto the lower alignment posts. Don't let the film touch the screen just yet.
  14. Motorola Razr+ Screen Protector Replacement, Apply the screen protector: passo 14, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Apply the screen protector: passo 14, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Apply the screen protector: passo 14, imagem 3 %32
    • During this step, keep the roller in contact with the screen. If you stop rolling and start somewhere else, creases might form under the protector.
    • Hold the protector tight over the lower alignment posts.
    • Use the roller to firmly roll the protector onto the top half of the screen, starting from the top edge.
    • When you reach the middle of the screen, lift the remaining half of the liner to a 45-degree angle.
    • Increase pressure on the roller and slowly roll across the hinge area of the screen.
    • When you pass the middle of the screen, lower the liner and finish rolling the bottom half of the protector onto the screen.
  15. Motorola Razr+ Screen Protector Replacement, Secure the screen protector: passo 15, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Secure the screen protector: passo 15, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Secure the screen protector: passo 15, imagem 3 %32
    Plastic Cards
    $2.99
    • Use the squeegee or a plastic card to press the top and bottom edges of the protector onto the screen.
    • Press around the perimeter of the screen, working out any bubbles toward the edges as you go.
  16. Motorola Razr+ Screen Protector Replacement, Separate the upper liner: passo 16, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Separate the upper liner: passo 16, imagem 2 %32
    • Peel the top right corner of the large liner away from the screen to separate it from the screen protector.
    • Make sure the protector doesn't peel up with the liner. If it does, use the squeegee to press it down, or try the other side.
  17. Motorola Razr+ Screen Protector Replacement, Remove the upper liner: passo 17, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Remove the upper liner: passo 17, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Remove the upper liner: passo 17, imagem 3 %32
    • Work down the long edge of the screen, peeling up the edge of the liner as you go.
    • Once you reach the bottom of the screen, fully peel the liner off and remove it from the adapter.
  18. Motorola Razr+ Screen Protector Replacement, Wipe away any imperfections: passo 18, imagem 1 %32
    • Use a microfiber or lint free cloth to wipe the screen protector and rub out any streaks or imperfections between it and the screen.
    • Work out any small bubbles by wiping toward the edges. If there are any large bubbles, the screen protector didn't adhere properly and needs to be replaced.
  19. Motorola Razr+ Screen Protector Replacement: passo 19, imagem 1 %32 Motorola Razr+ Screen Protector Replacement: passo 19, imagem 2 %32 Motorola Razr+ Screen Protector Replacement: passo 19, imagem 3 %32
    • Use your squeegee or a plastic card with a cloth to firmly rub along the perimeter of the screen protector to fully secure the edges to the screen.
    • If there are any large creases, especially near the hinge, the protector didn't adhere properly and needs to be replaced.
    • Small imperfections or streaks near the top and bottom of the screen will disappear within a couple of days.
  20. Motorola Razr+ Screen Protector Replacement, Remove the phone: passo 20, imagem 1 %32 Motorola Razr+ Screen Protector Replacement, Remove the phone: passo 20, imagem 2 %32 Motorola Razr+ Screen Protector Replacement, Remove the phone: passo 20, imagem 3 %32
    • To remove the phone, pull the spring‑loaded top adjuster with one hand, and use your free hand to lift and remove the phone.
Conclusão
4 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
102.723 Reputação
Autoria de 472 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 17.652 guias
8Comentários do guia
Not sure if I applied too much pressure but my screen broke after replacing the protector. I closed it and it broke.
Kaelyn Blair - Responder Compartilhar
$40 for a Screen protector kit is to much, and only one screen protector included. So if you mess up the first time you're SOL. The screen protector only lasted two days until it started to come off. Bought another replacement off amazon for $8, came with TWO screen protectors, and so far it has lasted longer then the $40 kit sold here. Would not recommend this kit at all, complete waste of money.
eximius100 - Responder Compartilhar
agreed. I was stupid enough to spend another $30 to get just the protector thinking I did it wrong the first time. Nope same thing looks great for 5 days and starts peeling off at the fold
Tanay Shah - Compartilhar
DON'T BUY IT. NOT WORTH IT. WASTE OF MONEY. I followed the exact directions and have air bubbles all over, it is not worth it. $40 plus tax and shipping for nothing but garbage. I made sure to read the directions several times and it screen saver is bad. The screen saver tried to go on crooked and hard to put on. If I could post a picture I would. I thought it would be better than the cheap ones off Amazon but they are by far better than this. The cover didn't fit the phone holder, it would fit one peg or the other on top and bottom but didn't fit one side of both ends. I think that is why it gave me bubbles that I can't get out. I would rather have the original that was peeling off then waste money on this. I will go to another place that has cheaper screen savers that will work. It is the same screen saver as the cheap ones. I can't wait to get a cheaper one that works better!! So, in conclusion I wish I had read these comments before buying. You will still will have to another screen saver. Don't buy this.
Michelle S - Responder Compartilhar
This screen saver just ruined my phone. I have a Motorola Razr plus and I followed directions exactly, had tons of air bubbles I couldn't get out and took it off. My phone doesn't work. I have to use small screen on outside as I have a black screen of death where I'm supposed to have dial pad, phone numbers and apps. DON'T BUY IT. I AM P*SSED, PHONE NOT EVEN PAID FOR AND IT'S RUINED. I STILL OWE 2 YEARS OF PAYMENTS ON IT.
Comentar
Visualizações:
Últimas 24 horas: 30
Últimos 7 dias: 232
Últimos 30 dias: 1,050
Ao todo: 25,477
