Ir para o conteúdo principal
Motorola RIZR Z3 LCD Replacement
O que você precisa
  1. Motorola RIZR Z3 LCD Replacement, Battery: passo 1, imagem 1 %32 Motorola RIZR Z3 LCD Replacement, Battery: passo 1, imagem 2 %32
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola RIZR Z3 LCD Replacement: passo 2, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 2, imagem 2 %32
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
    Pergunte ao FixBot
    Comentar
  3. Motorola RIZR Z3 LCD Replacement, Motherboard: passo 3, imagem 1 %32
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
    Pergunte ao FixBot
    Comentar
  4. Motorola RIZR Z3 LCD Replacement: passo 4, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola RIZR Z3 LCD Replacement: passo 5, imagem 1 %32
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
    Pergunte ao FixBot
    Comentar
  6. Motorola RIZR Z3 LCD Replacement: passo 6, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
    Pergunte ao FixBot
    Comentar
  7. Motorola RIZR Z3 LCD Replacement: passo 7, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
    Pergunte ao FixBot
    Comentar
  8. Motorola RIZR Z3 LCD Replacement: passo 8, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
    Pergunte ao FixBot
    Comentar
  9. Motorola RIZR Z3 LCD Replacement, LCD: passo 9, imagem 1 %32
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
    Pergunte ao FixBot
    Comentar
  10. Motorola RIZR Z3 LCD Replacement: passo 10, imagem 1 %32
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
    Pergunte ao FixBot
    Comentar
  11. Motorola RIZR Z3 LCD Replacement: passo 11, imagem 1 %32
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
    Pergunte ao FixBot
    Comentar
  12. Motorola RIZR Z3 LCD Replacement: passo 12, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 12, imagem 2 %32 Motorola RIZR Z3 LCD Replacement: passo 12, imagem 3 %32
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
    • Pull the plastic screen casing directly away from the LCD unit.
    Pergunte ao FixBot
    Comentar
  13. Motorola RIZR Z3 LCD Replacement: passo 13, imagem 1 %32 Motorola RIZR Z3 LCD Replacement: passo 13, imagem 2 %32
    • Use a spudger to lift the LCD partially away from the metal casing.
    • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
    • Caution: Damage to the ribbon cable here will cause screen damage.
    • Pull the LCD completely away from the metal casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 5-34, Amido Fall 2011 Membro de Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 43
Ao todo: 1,303
