Ir para o conteúdo principal
Motorola RAZR Maxx HD Screen Replacement
O que você precisa
  1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: passo 1, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement, Screen Removal: passo 1, imagem 2 %32
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola RAZR Maxx HD Screen Replacement: passo 2, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement: passo 2, imagem 2 %32
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
    Pergunte ao FixBot
    Comentar
  3. Motorola RAZR Maxx HD Screen Replacement: passo 3, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement: passo 3, imagem 2 %32
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
    Pergunte ao FixBot
    Comentar
  4. Motorola RAZR Maxx HD Screen Replacement: passo 4, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement: passo 4, imagem 2 %32
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
    Pergunte ao FixBot
    Comentar
  5. Motorola RAZR Maxx HD Screen Replacement, Front-Facing Camera: passo 5, imagem 1 %32
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
    Pergunte ao FixBot
    Comentar
  6. Motorola RAZR Maxx HD Screen Replacement: passo 6, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement: passo 6, imagem 2 %32 Motorola RAZR Maxx HD Screen Replacement: passo 6, imagem 3 %32
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
    Pergunte ao FixBot
    Comentar
  7. Motorola RAZR Maxx HD Screen Replacement: passo 7, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
    Pergunte ao FixBot
    Comentar
  8. Motorola RAZR Maxx HD Screen Replacement, Earpiece Speaker: passo 8, imagem 1 %32
    • Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
    Pergunte ao FixBot
    Comentar
  9. Motorola RAZR Maxx HD Screen Replacement: passo 9, imagem 1 %32 Motorola RAZR Maxx HD Screen Replacement: passo 9, imagem 2 %32
    • Using a spudger, gently pry up on the lower right edge of the black earpiece speaker ribbon cable, attached to the screen, to release it from the LCD display.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Enrique
Membro desde: 02/01/15
371 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-40, Amido Winter 2015 Membro de Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Membros
Autoria de 27 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Ao todo: 3,174
