Ir para o conteúdo principal
Motorola RAZR Maxx HD Battery Replacement
O que você precisa
  1. Motorola RAZR Maxx HD Battery Replacement, Screen Removal: passo 1, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement, Screen Removal: passo 1, imagem 2 %32
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola RAZR Maxx HD Battery Replacement: passo 2, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 2, imagem 2 %32
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
    Pergunte ao FixBot
    Comentar
  3. Motorola RAZR Maxx HD Battery Replacement: passo 3, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 3, imagem 2 %32
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
    Pergunte ao FixBot
    Comentar
  4. Motorola RAZR Maxx HD Battery Replacement: passo 4, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 4, imagem 2 %32
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
    Pergunte ao FixBot
    Comentar
  5. Motorola RAZR Maxx HD Battery Replacement, Circuit Board: passo 5, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: passo 5, imagem 2 %32 Motorola RAZR Maxx HD Battery Replacement, Circuit Board: passo 5, imagem 3 %32
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Motorola RAZR Maxx HD Battery Replacement: passo 6, imagem 1 %32
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Motorola RAZR Maxx HD Battery Replacement: passo 7, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
    Pergunte ao FixBot
    Comentar
  8. Motorola RAZR Maxx HD Battery Replacement: passo 8, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 8, imagem 2 %32
    • Using tweezers, remove the back facing camera cover.
    Pergunte ao FixBot
    Comentar
  9. Motorola RAZR Maxx HD Battery Replacement: passo 9, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 9, imagem 2 %32
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Motorola RAZR Maxx HD Battery Replacement: passo 10, imagem 1 %32
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
    Pergunte ao FixBot
    Comentar
  11. Motorola RAZR Maxx HD Battery Replacement: passo 11, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement: passo 11, imagem 2 %32 Motorola RAZR Maxx HD Battery Replacement: passo 11, imagem 3 %32
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
    Pergunte ao FixBot
    Comentar
  12. Motorola RAZR Maxx HD Battery Replacement, Battery: passo 12, imagem 1 %32 Motorola RAZR Maxx HD Battery Replacement, Battery: passo 12, imagem 2 %32
    • Wedge the spudger tool under the battery to remove it from the back case.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Anna Sullivan
Membro desde: 02/01/15
880 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 8-40, Amido Winter 2015 Membro de Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Membros
Autoria de 27 guias
1Comentário do guia
When putting it all back together, is it recommended to replace the pieces of tape to protect/insulate the connectors, or is that not necessary?
FreeMan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Ao todo: 5,942
