Introdução
If your Moto Z2 Force camera is damaged or broken, this guide will show you how to replace it.
  1. Place the phone on a flat surface with the screen facing up.
    • Place the phone on a flat surface with the screen facing up.
    • Insert the flat end of a nylon spudger into the crease separating the screen and the body in the lower right corner of the phone.
    • Pry open part of the screen by pulling the tool and the screen toward you.
    • You may be required to use a heating element, such as the iOpener, to heat and loosen the adhesive underneath before attempting to pry it open.
  2. Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open. Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you. Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
    • Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
    • Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
    • Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
    • Remove the screen gently and slowly as the screen may crack otherwise.
  3. Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device. Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device.
    • Remove the screen by pulling from right to left and placing the screen face down on the flat surface next to the main body of the device.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to. Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to.
    • Using the flat end of the nylon spudger, pull off the black tape on top of the screen connector piece that the black ribbon is attached to.
  6. Insert the black spudger under the lock of the latch connecting the black ribbon of the screen to the phone body. Pull up on the lock to unlock the latch.
    • Insert the black spudger under the lock of the latch connecting the black ribbon of the screen to the phone body.
    • Pull up on the lock to unlock the latch.
    • Separate the black ribbon from the latch by pulling gently to the left.
  7. Unscrew the two 3mm T4 screws from the speaker. Unscrew the two 3mm T4 screws from the speaker. Unscrew the two 3mm T4 screws from the speaker.
    • Unscrew the two 3mm T4 screws from the speaker.
  8. Use the nylon spudger to lift and remove the speaker from the phone chassis. Use the nylon spudger to lift and remove the speaker from the phone chassis. Use the nylon spudger to lift and remove the speaker from the phone chassis.
    • Use the nylon spudger to lift and remove the speaker from the phone chassis.
  9. Insert the flat end of the nylon spudger on the side of the camera closest to the battery. Pry up the camera by pushing down on the spudger until the camera pops up.
    • Insert the flat end of the nylon spudger on the side of the camera closest to the battery.
    • Pry up the camera by pushing down on the spudger until the camera pops up.
  10. Insert the flat end of the nylon spudger underneath the black lock. Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
    • Insert the flat end of the nylon spudger underneath the black lock.
    • Unlock the ribbon cable by pulling up on the lock with the nylon spudger.
    • Separate the camera from the board by pulling gently towards the bottom of the phone.
Conclusão
Nick Schnorr
85 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S2-G1, Livingston Winter 2018 Membro de Cal Poly, Team S2-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G1
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 92
Todo: 824
