Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is a prerequisite only guide.
Suffering from a rapidly waning, or non-existent, battery life? Use this guide to replace the battery in your Motorola Moto X.
O que você precisa
Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
Use the flat end of a spudger to disconnect the NFC antenna cable connector.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto X Answers community for troubleshooting help.
