Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
Use the flat end of a spudger to disconnect the NFC antenna cable connector.
Use the tip of a spudger to flip up the ZIF retaining flap from the button assembly cable connector.
Slide the tip of the spudger under the button assembly cable near the connector to pull the cable straight out of its socket.
Insert the flat end of a spudger under the interconnect cable to free it from the adhesive holding it to the battery.
Use the flat end of a spudger to peel the adhesive pull-tab off the top of battery.
Ferramenta utilizada nesse passo:Tesa 61395 Tape$5.99-
Use the adhesive pull-tab to lift the battery from its recess.
Remove the battery from the phone.
