Ir para o conteúdo principal
Motorola Moto G7 Play Speaker Replacement
O que você precisa
  1. Motorola Moto G7 Play Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto G7 Play Speaker Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Speaker Replacement: passo 2, imagem 1 %32
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Speaker Replacement: passo 3, imagem 1 %32 Motorola Moto G7 Play Speaker Replacement: passo 3, imagem 2 %32
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Speaker Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Speaker Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Speaker Replacement: passo 6, imagem 1 %32 Motorola Moto G7 Play Speaker Replacement: passo 6, imagem 2 %32
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Speaker Replacement: passo 7, imagem 1 %32 Motorola Moto G7 Play Speaker Replacement: passo 7, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
  8. Motorola Moto G7 Play Speaker Replacement, Speaker: passo 8, imagem 1 %32 Motorola Moto G7 Play Speaker Replacement, Speaker: passo 8, imagem 2 %32
    • Use the spudger to remove the speaker from the top of the phone.
Conclusão
2 comentários
Nice guide to repair any mobile phone
Fisseha Desta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 33
Duração total: 1,226
