Introdução
This motherboard replacement guide should be attempted if other parts of the device were replaced, but the problem persisted. The steps should be followed for the Motorola G7 Play, models XT1952-3 and XT1952-2. The motherboard powers the whole device and makes it function, so it’s a very important part that should be replaced if it is damaged.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
