Ir para o conteúdo principal
Motorola Moto G7 Play Motherboard Replacement
O que você precisa
  1. Motorola Moto G7 Play Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto G7 Play Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Motherboard Replacement: passo 2, imagem 1 %32
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Motherboard Replacement: passo 3, imagem 1 %32 Motorola Moto G7 Play Motherboard Replacement: passo 3, imagem 2 %32
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Motherboard Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Motherboard Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Motherboard Replacement: passo 6, imagem 1 %32 Motorola Moto G7 Play Motherboard Replacement: passo 6, imagem 2 %32
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Motherboard Replacement: passo 7, imagem 1 %32 Motorola Moto G7 Play Motherboard Replacement: passo 7, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
Conclusão
Monserath Casillas
Membro desde: 02/10/20
1.161 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S7-G4, Regan Winter 2020 Membro de Cal Poly, Team S7-G4, Regan Winter 2020
CPSU-REGAN-W20S7G4
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 32
Duração total: 2,255
