Introdução
This guide will show each detailed step to removing and replacing the front facing in the Motorola G7 Play, model number XT1952-3 or XT1952-2. The front camera is used to take selfie photos on the phone. If the phone doesn’t have a way to capture selfie photos the front facing camera is no longer working.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
Separate the front facing camera from the motherboard while removing the adhesive .
