Ir para o conteúdo principal
Motorola Moto G7 Play Fingerprint Sensor Replacement
O que você precisa
  1. Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto G7 Play Fingerprint Sensor Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Fingerprint Sensor Replacement: passo 2, imagem 1 %32
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Fingerprint Sensor Replacement: passo 3, imagem 1 %32 Motorola Moto G7 Play Fingerprint Sensor Replacement: passo 3, imagem 2 %32
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Fingerprint Sensor Replacement, Fingerprint Sensor: passo 4, imagem 1 %32
    • Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Fingerprint Sensor Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed
  6. Motorola Moto G7 Play Fingerprint Sensor Replacement: passo 6, imagem 1 %32 Motorola Moto G7 Play Fingerprint Sensor Replacement: passo 6, imagem 2 %32
    • Using the iFixit opening tool, carefully disconnect the ribbon cable connecting the fingerprint scanner to the motherboard.
    • Remove the fingerprint scanner from the device.
Conclusão
3 outras pessoas executaram este guia.
Monserath Casillas
Membro desde: 02/10/20
1.161 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S7-G4, Regan Winter 2020 Membro de Cal Poly, Team S7-G4, Regan Winter 2020
CPSU-REGAN-W20S7G4
Membros da 5
Autoria de 12 guias
Um comentário
Do you need to replace the adhesive on the rear cover? Or is it reusable?
wtwolfe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 1,691
