Introdução
In this guide, we will be walking through how to remove the front camera of the Motorola Moto G3.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
Uma outra pessoa concluiu este guia.
