Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
In this guide, we will be walking through how to remove the front camera of the Motorola Moto G3.
  1. Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover. Make sure to fully power off the phone before you begin disassembly.
    • Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
    • Make sure to fully power off the phone before you begin disassembly.
  2. Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener. Evenly apply heat to the edges of the touchscreen to loosen the adhesive.  Continue to Step 3 once the edge of the screen is warm to the touch.
    • Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener.
    • Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
    • Do not let the iOpener/heat gun remain on one spot for too long. Excess heat can damage the phone.
    • When reassembling the phone, use the iOpener/heat gun to help the adhesive fuse to the new screen. Heat the screen edges, apply pressure to the screen, and hold the screen in place until it is secure.
  3. As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick.  A suction cup may also be useful here. Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary. Avoid damaging the LCD screen connector while prying along the screen edges.  It is located on the left edge of the phone, across from the volume controls.
    • As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
    • Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
    • Avoid damaging the LCD screen connector while prying along the screen edges. It is located on the left edge of the phone, across from the volume controls.
    • During reassembly, new adhesive may need to be applied over the old adhesive to properly secure the screen.
    • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
    • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Confira os kits
    Enough RAM
    For All The Tabs
    Confira os kits
  5. Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
    • Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
    • Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
  6. If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
    • If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
    • Carefully lift the right edge of the motherboard from the phone.
    • Avoid pulling on the battery wires, which connect the left underside of the motherboard to the battery.
  7. Use a plastic opening tool to disconnect the battery wires from the motherboard.
    • Use a plastic opening tool to disconnect the battery wires from the motherboard.
  8. Flip the motherboard over.
    • Flip the motherboard over.
  9. Using tweezers, pry open the black front camera cover and remove it from the motherboard.
    • Using tweezers, pry open the black front camera cover and remove it from the motherboard.
  10. Remove the front camera from the device.
    • Remove the front camera from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Irkan Notta
Membro desde: 19/03/2018
1.034 Reputação
7 Guias de autoria
Equipe
Baylor, Team S5-G3, Williams Spring 2018 Membro de Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 Membros
8 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 29
Duração total: 769
