Introdução
This guide will teach you to replace the charging port in a Moto G Power (2020). If you're experiencing other issues, please check out our troubleshooting page.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Place a suction cup on the back of the device.
Then open up the back of the device by sliding the opening pick into both sides of the phone.
6 outras pessoas executaram este guia.
2 comentários
This guide is good, but understates the ease of taking the back off. There is adhesive holding it on, and it took a heat gun and a LOT of force to pry it open. I only found out when I was trying to tell which of the two shell grooves I needed to pry open (the back one, since there's no side view) and found a different guide on Youtube, and saw them using a heating pad. I also couldn't tell WHICH 3 screws of the 5 were necessary to remove, so I just did all 5. Some circling would help!
Outside of that, thank you so much for the guide, I fixed my first phone all by my self! Minus borrowing my dad's heat gun and the two of us working together to pry the case open, seriously that was the hardest part. Once the case is open, the rest is EASY!! Now to get the dang case back on...
You did not show how to connect the broken charger port do u soder it in or what I'm looking into this
