Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Device Overheating
Your device is overheating during charge or use, it's uncomfortable to hold the device.
Using low-quality, 3rd party charging devices
Use the PROVIDED charging devices (aka. charging bricks and cables
Operating the device with high intensity apps for long period of time
DO NOT place the device under direct sunlight
Temperature of the environment
DO NOT use "fast" chargers with high wattage capacity
Dirty interior due to extensive use
Clean and maintain the device once in a while!
Unable to Charge the Device
The device is unable to be charged or will not respond or any sign of powering up.
Damaged charging cables
Test the charging cable & brick with another device. If the new device cannot be charged with the same charging devices, then you'll know that either the cable or brick.
Damaged charging port/battery/Software malfunction
If the new device can be charged with the same charging devices, then you'll know that the issue is caused by your device. This could mean either software malfunction, damaged battery, or dirty/damaged charging port. The issue could any combinations of above.
Slow Performance
The device is slower than expected performance.
Prolonged usage of high intensity applications
Restart your phone to get rid of any glitches. Take a break in between long and intensive gaming or video editing to lower the temperature of the device. High temperature can lead to slower performance.
Extremely dirty internal of the device
If you have not cleaned your device in a while (or never!), then you may experience slow performance due to a lot of dirt collecting inside of the device causing overheating , which impacts the performance.
Update your software to latest available from your provider. Old software could cause slow performance due to optimization issues.
Unable to Connect to Wifi
Your device is unable to connect to network such as WiFi and LTE.
Update your software to latest available from your provider. Old software may have a lot bugs and glitches, update to the latest as soon as possible!
Issues with network setting
Reset your network settings.
First, go to settings in your device
Second, go to "Network"
Third, scroll down and click on "Reset Network Settings)
Environmental Problems (location, and other interference)
Make sure there are no interference by environmental factors such as walls, trees, and distance from the network source.
Um comentário
someone accessed my phone and it hAS APPS THAT DONT BELONG ON THERE
K Tu - Responder
