Introdução
Follow this guide to remove or replace the daughterboard in a Motorola Moto E6 Plus. The daughterboard assembly includes both the charging port and the vibration motor which is soldered on.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Use an opening tool or your fingernail to pry the back cover away from the frame using the notch at the bottom right corner.
Use an opening tool or your fingernail to release the clips on the right edge by sliding up and around the top right corner.
Continue to slide the opening tool or your fingernail across the top edge to release the clips securing the back cover to the frame.
Continue to slide the opening tool or your fingernail down the left edge to release the clips.
Use a spudger or your fingernail to pry the battery up using the notch near the bottom right corner.
Remove the battery.
Use a Torx T3 driver to remove the three 3.6 mm-long screws securing the loudspeaker to the frame.
Use a Phillips screwdriver to remove the four 3.1 mm-long screws.
Use the pointed end of a spudger to disconnect the coaxial cable by lifting straight up as close to the connector as possible.
Use the flat end of a spudger to disconnect the motherboard flex cable by lifting straight up on the press connector.
Heat an iOpener and apply it to the bottom edge of the screen for 30 seconds.
Apply a few drops of high concentration (over 90%) isopropyl alcohol underneath the vibration motor to loosen the adhesive securing it to the frame.
Tilt your phone to allow the isopropyl alcohol to flow underneath the vibration motor.
Use an opening pick to peel the vibration motor off the frame.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto E6 Plus Answers community for help.
