Introdução
The Motorola Moto E6 Play phone runs on a 3000 mAh rechargeable battery. If the phone will not power on, there may be an issue with the battery. Before attempting this guide, click here for troubleshooting issues with the device not powering on. Before beginning any repairs, remember to completely turn off the phone, and check for signs of a swollen battery, which is chemically hazardous and can cause fires if improperly dealt with.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Run the halberd spudger along the edges of the device. The back cover should easily pop off.
To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
3 outras pessoas executaram este guia.
