Ir para o conteúdo principal
Motorola Moto E4 Plus Battery Replacement
O que você precisa
  1. Motorola Moto E4 Plus Battery Replacement, Remove the back cover: passo 1, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: passo 1, imagem 2 %32 Motorola Moto E4 Plus Battery Replacement, Remove the back cover: passo 1, imagem 3 %32
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Battery Replacement: passo 2, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 2, imagem 2 %32
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Battery Replacement, Midframe: passo 3, imagem 1 %32
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Battery Replacement: passo 4, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 4, imagem 2 %32
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Battery Replacement: passo 5, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 5, imagem 2 %32 Motorola Moto E4 Plus Battery Replacement: passo 5, imagem 3 %32
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Battery Replacement: passo 6, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 6, imagem 2 %32
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Battery Replacement: passo 7, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 7, imagem 2 %32
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Battery Replacement: passo 8, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 8, imagem 2 %32
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: passo 9, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement, Battery Disconnect: passo 9, imagem 2 %32
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Battery Replacement, Battery: passo 10, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement, Battery: passo 10, imagem 2 %32 Motorola Moto E4 Plus Battery Replacement, Battery: passo 10, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to peel the ends of the two pull tabs off of the bottom edge of the battery.
  11. Motorola Moto E4 Plus Battery Replacement: passo 11, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 11, imagem 2 %32 Motorola Moto E4 Plus Battery Replacement: passo 11, imagem 3 %32
    • Pull out the left adhesive strip by steadily pulling the left tab at a flat angle.
    • If the adhesive strip rips, grab and twist the remaining stub around the tip of a pair of tweezers a couple of times and then continue pulling.
    • Repeat the same process for the right adhesive strip.
  12. Motorola Moto E4 Plus Battery Replacement: passo 12, imagem 1 %32 Motorola Moto E4 Plus Battery Replacement: passo 12, imagem 2 %32
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape.
    • In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery.
    • Press the new battery firmly into place for 5-10 seconds.
Conclusão
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
19 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
211.758 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.077 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 114
Duração total: 22,660
