Introdução
Use this guide to replace a broken or defective LCD and digitizer in your Motorola Moto E4 (XT1762).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
This guide shows you how to replace the display and digitizer. Make sure you have the correct part before starting this guide.
You may need replacement adhesive to reattach components during reassembly.
For replacing the screen assembly including the frame use this guide.
O que você precisa
Insert a fingernail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
Move to the bottom left corner to pry the phone out of the back cover.
Use a fingernail or spudger to pry at the notch at the bottom end of the battery.
Lever the battery out of its recess and remove it.
Prepare an iOpener and apply it to the edges of the display for at least two minutes to loosen the adhesive beneath.
Apply an iOpener for about one minute to the bottom end of the display where the home button is located.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. If the replacement part does not come with adhesive preinstalled apply tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
5 outras pessoas executaram este guia.
2 comentários
Nicely done guide! Thank you!
