Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This panel should be removed to get to all of the watch's insides. It is extremely fragile, so use caution when removing it.
O que você precisa
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
9 outras pessoas executaram este guia.
Um comentário
How does this *rear cover replacement* count as "no parts required"?
