Ir para o conteúdo principal
Motorola Moto 360 Rear Cover Replacement
O que você precisa
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: passo 1, imagem 1 %32
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Rear Cover Replacement: passo 3, imagem 1 %32 Motorola Moto 360 Rear Cover Replacement: passo 3, imagem 2 %32
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: passo 4, imagem 1 %32
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
Conclusão
9 outras pessoas executaram este guia.
Cole Twitchell
Membro desde: 01/30/15
1.688 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-32, Amido Winter 2015 Membro de Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Membros
Autoria de 18 guias
1Comentário do guia
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 13,128
