Introdução
The O-Ring is fragile. Take care not to let it break when dealing with it.
O que você precisa
Set the watch face down on a flat surface.
Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
Follow the instructions here to remove the back cover without force by using some needles in the right places:
Then continue with step 5. Or don't use needles and just continue with the next steps.
3Comentários do guia
Where can you get your hands on a replacement o'ring?!
I broke my o-ring. Any ideas where I could get a raplacement?
i think you should not take the o ring. i was replaceing the battery without take the O ring
