Ir para o conteúdo principal
Motorola Moto 360 LCD Display Replacement
O que você precisa
  1. Motorola Moto 360 LCD Display Replacement, Rear Cover: passo 1, imagem 1 %32
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 LCD Display Replacement: passo 3, imagem 1 %32 Motorola Moto 360 LCD Display Replacement: passo 3, imagem 2 %32
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 LCD Display Replacement: passo 4, imagem 1 %32
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 LCD Display Replacement, O-Ring: passo 5, imagem 1 %32 Motorola Moto 360 LCD Display Replacement, O-Ring: passo 5, imagem 2 %32
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 LCD Display Replacement: passo 6, imagem 1 %32
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
  6. Motorola Moto 360 LCD Display Replacement, LCD Display: passo 7, imagem 1 %32
    • Set the Moto 360 face up on a flat surface.
    • Place the iOpener on the face of the device screen.
  7. Motorola Moto 360 LCD Display Replacement: passo 8, imagem 1 %32 Motorola Moto 360 LCD Display Replacement: passo 8, imagem 2 %32
    • Gently slide the opening pick between the screen and the metal casing.
    • Work your way around the face of the screen, loosening the adhesive.
  8. Motorola Moto 360 LCD Display Replacement: passo 9, imagem 1 %32 Motorola Moto 360 LCD Display Replacement: passo 9, imagem 2 %32
    • Detach the copper ribbon connecting the motherboard to the display.
    • For reassembly, attach copper ribbon where it is marked.
    • The copper ribbon is fragile and easily disconnects. Remember where it goes so as to reconnect it properly.
  9. Motorola Moto 360 LCD Display Replacement: passo 10, imagem 1 %32
    • Slide the display out of the metal casing.
Conclusão
15 outras pessoas executaram este guia.
Cole Twitchell
Membro desde: 01/30/15
1.688 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-32, Amido Winter 2015 Membro de Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Membros
Autoria de 18 guias
7Comentários do guia
Good morning,
It is possible to replace the display unit for the Moto 360 2nd with 1.56" display?
Thanks in advance and best regards,
Stephan
Stephan Müller - Responder
Were could i buy a new lcd screen for the moto 360 1st gen??
Sebastian Galvan - Responder
hey mate you can buy one from aliexpress aliexpress moto 360 screen see link below
https://goo.gl/ZSMTVW
Faddy Oraha -
Where can I get a LCD display for a Moto 360 2 gen 42mm. Thanks hope you can help
Glenn Patoska - Responder
Bonjour,
Où est-il possible de trouver des pièces détachées ?
Le fond du boitier.
Merci de votre réponse.
DOGUE - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 73
Ao todo: 22,098
