Ir para o conteúdo principal
Motorola MBP667CONNECT Circuit Board Replacement
O que você precisa
  1. Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: passo 1, imagem 2 %32 Motorola MBP667CONNECT Circuit Board Replacement, Circuit Board: passo 1, imagem 3 %32
    • Remove the two 5 mm Phillips #1 screws on the back of the camera.
    • Use a nylon spudger to remove the casing.
  2. Motorola MBP667CONNECT Circuit Board Replacement: passo 2, imagem 1 %32 Motorola MBP667CONNECT Circuit Board Replacement: passo 2, imagem 2 %32 Motorola MBP667CONNECT Circuit Board Replacement: passo 2, imagem 3 %32
    • Remove the brackets by the speaker on the front side of the camera using the metal spudger.
    • Continue to use the metal spudger to carefully disconnect remaining brackets from casing.
    • Remove the two 5mm Phillips #1 screws on the backside of the camera.
  3. Motorola MBP667CONNECT Circuit Board Replacement: passo 3, imagem 1 %32 Motorola MBP667CONNECT Circuit Board Replacement: passo 3, imagem 2 %32 Motorola MBP667CONNECT Circuit Board Replacement: passo 3, imagem 3 %32
    • Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
    • Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
    • Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
  4. Motorola MBP667CONNECT Circuit Board Replacement: passo 4, imagem 1 %32 Motorola MBP667CONNECT Circuit Board Replacement: passo 4, imagem 2 %32
    • You will now be able to carefully pull the receiver wire through the gap in the casing.
Conclusão
Jordan Webb
Membro desde: 01/16/19
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 376
