Introdução
Use this guide to replace the camera bezel on your Motorola Edge (2022).
You'll need replacement adhesive in order to complete this repair.
O que você precisa
Heat an iOpener and apply it to the back cover's right edge for two minutes.
Insert an opening pick between the camera bezel and the back cover.
Slide the pick around the perimeter of the camera bezel to slice all the adhesive securing the bezel.
To reassemble your device, follow the instructions in reverse order.
