Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the phone.
Heat an iOpener and apply it to the top edge of the phone for a minute.
Angle an opening pick and firmly press so that it slips under the back cover.
Slide the opening pick along the top edge of the phone to break up the adhesive.
Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
Repeat the iOpener heating and slicing procedures for the remaining three sides.
Once you have cut through the adhesive, slowly peel the back cover away from the frame.
Remove the back cover.
Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
Use the point of a spudger to pry up and remove the coil connector rubber cover.
To reinstall the cover, align the cover and use your finger to push it forward into place.
Use the point of a spudger to pry up and disconnect the flash connector.
Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
Remove the following T3 screws securing the midframe:
Thirteen 3.1 mm black screws
Four 4.3 mm silver screws
Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
4 outras pessoas executaram este guia.
3 comentários
Other than the comments I left above, I felt this was a nice simple-to-follow guide that gives me confidence to try this myself.
If you fix the items listed above, it will be perfect.
Thanks!
Where can I buy a good T3 screwdriver?
I have tried 3 brands and the screwdriver rounds off instead of removing the screw.
