Ir para o conteúdo principal
Motorola Droid Pro Screen Replacement
O que você precisa
  1. Motorola Droid Pro Screen Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover using the thumb tab located on the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola Droid Pro Screen Replacement: passo 2, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 2, imagem 2 %32
    • Remove the battery using the thumb tab.
    Pergunte ao FixBot
    Comentar
  3. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: passo 3, imagem 1 %32 Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: passo 3, imagem 2 %32
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
    Pergunte ao FixBot
    Comentar
  4. Motorola Droid Pro Screen Replacement: passo 4, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 4, imagem 2 %32 Motorola Droid Pro Screen Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
    Pergunte ao FixBot
    Comentar
  5. Motorola Droid Pro Screen Replacement: passo 5, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 5, imagem 2 %32
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
    Pergunte ao FixBot
    Comentar
  6. Motorola Droid Pro Screen Replacement, Motherboard: passo 6, imagem 1 %32 Motorola Droid Pro Screen Replacement, Motherboard: passo 6, imagem 2 %32
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
    Pergunte ao FixBot
    Comentar
  7. Motorola Droid Pro Screen Replacement: passo 7, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 7, imagem 2 %32
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
    Pergunte ao FixBot
    Comentar
  8. Motorola Droid Pro Screen Replacement: passo 8, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 8, imagem 2 %32
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
    Pergunte ao FixBot
    Comentar
  9. Motorola Droid Pro Screen Replacement: passo 9, imagem 1 %32
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
    Pergunte ao FixBot
    Comentar
  10. Motorola Droid Pro Screen Replacement: passo 10, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 10, imagem 2 %32 Motorola Droid Pro Screen Replacement: passo 10, imagem 3 %32
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
    Pergunte ao FixBot
    Comentar
  11. Motorola Droid Pro Screen Replacement: passo 11, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 11, imagem 2 %32
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
    Pergunte ao FixBot
    Comentar
  12. Motorola Droid Pro Screen Replacement, Screen: passo 12, imagem 1 %32 Motorola Droid Pro Screen Replacement, Screen: passo 12, imagem 2 %32
    • Use a T4 Torx Screwdriver to remove the (6) 1mm screws.
    Pergunte ao FixBot
    Comentar
  13. Motorola Droid Pro Screen Replacement: passo 13, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 13, imagem 2 %32 Motorola Droid Pro Screen Replacement: passo 13, imagem 3 %32
    • Using a plastic opening tool or spudger lift the rear screen plate up and pull it off.
    Pergunte ao FixBot
    Comentar
  14. Motorola Droid Pro Screen Replacement: passo 14, imagem 1 %32 Motorola Droid Pro Screen Replacement: passo 14, imagem 2 %32 Motorola Droid Pro Screen Replacement: passo 14, imagem 3 %32
    • Unlock the screen's ribbon cable.
    • The mechanism that locks the ribbon cable in place for the screen is very weak, so be careful.
    • To remove the screen, you have to flip the phone over and let it fall out slowly into your hand. Be careful not to put any tension on the ribbon cable.
    • Then pull the screen away from the ribbon cable connector and it will slide out easily. Do not use excessive force.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Kyle Shays
Membro desde: 10/28/15
836 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 1-6, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 665
