Ir para o conteúdo principal
Motorola Droid Pro Motherboard Replacement
O que você precisa
  1. Motorola Droid Pro Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover using the thumb tab located on the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola Droid Pro Motherboard Replacement: passo 2, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the battery using the thumb tab.
    Pergunte ao FixBot
    Comentar
  3. Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: passo 3, imagem 1 %32 Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: passo 3, imagem 2 %32
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
    Pergunte ao FixBot
    Comentar
  4. Motorola Droid Pro Motherboard Replacement: passo 4, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 4, imagem 2 %32 Motorola Droid Pro Motherboard Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
    Pergunte ao FixBot
    Comentar
  5. Motorola Droid Pro Motherboard Replacement: passo 5, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 5, imagem 2 %32
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
    Pergunte ao FixBot
    Comentar
  6. Motorola Droid Pro Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Motorola Droid Pro Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
    Pergunte ao FixBot
    Comentar
  7. Motorola Droid Pro Motherboard Replacement: passo 7, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 7, imagem 2 %32
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
    Pergunte ao FixBot
    Comentar
  8. Motorola Droid Pro Motherboard Replacement: passo 8, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 8, imagem 2 %32
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
    Pergunte ao FixBot
    Comentar
  9. Motorola Droid Pro Motherboard Replacement: passo 9, imagem 1 %32
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
    Pergunte ao FixBot
    Comentar
  10. Motorola Droid Pro Motherboard Replacement: passo 10, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 10, imagem 2 %32 Motorola Droid Pro Motherboard Replacement: passo 10, imagem 3 %32
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
    Pergunte ao FixBot
    Comentar
  11. Motorola Droid Pro Motherboard Replacement: passo 11, imagem 1 %32 Motorola Droid Pro Motherboard Replacement: passo 11, imagem 2 %32
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 1-6, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 668
