Ir para o conteúdo principal
Motorola Droid Motherboard Replacement
O que você precisa
  1. Motorola Droid Motherboard Replacement, Battery: passo 1, imagem 1 %32 Motorola Droid Motherboard Replacement, Battery: passo 1, imagem 2 %32 Motorola Droid Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
    • Lift and remove the battery cover out from the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola Droid Motherboard Replacement: passo 2, imagem 1 %32
    • Grasp the upper left corner of the battery and lift it out of its housing.
    Pergunte ao FixBot
    Comentar
  3. Motorola Droid Motherboard Replacement, Rear Case: passo 3, imagem 1 %32
    • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
    • The cover is attached by adhesive, so some force may be required.
    Pergunte ao FixBot
    Comentar
  4. Motorola Droid Motherboard Replacement: passo 4, imagem 1 %32 Motorola Droid Motherboard Replacement: passo 4, imagem 2 %32
    • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
    • Peel the ribbon up off the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola Droid Motherboard Replacement: passo 5, imagem 1 %32 Motorola Droid Motherboard Replacement: passo 5, imagem 2 %32
    • Carefully peel the device information label that covers the motherboard EMI shields.
    • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
    Pergunte ao FixBot
    Comentar
  6. Motorola Droid Motherboard Replacement: passo 6, imagem 1 %32
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
    Pergunte ao FixBot
    Comentar
  7. Motorola Droid Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
    Pergunte ao FixBot
    Comentar
  8. Motorola Droid Motherboard Replacement: passo 8, imagem 1 %32
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
    Pergunte ao FixBot
    Comentar
  9. Motorola Droid Motherboard Replacement: passo 9, imagem 1 %32
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  10. Motorola Droid Motherboard Replacement: passo 10, imagem 1 %32 Motorola Droid Motherboard Replacement: passo 10, imagem 2 %32
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
    Pergunte ao FixBot
    Comentar
  11. Motorola Droid Motherboard Replacement: passo 11, imagem 1 %32 Motorola Droid Motherboard Replacement: passo 11, imagem 2 %32
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    Pergunte ao FixBot
    Comentar
  12. Motorola Droid Motherboard Replacement, Speaker: passo 12, imagem 1 %32
    • Carefully lift and remove the speaker assembly up out of the phone.
    Pergunte ao FixBot
    Comentar
  13. Motorola Droid Motherboard Replacement, Motherboard: passo 13, imagem 1 %32 Motorola Droid Motherboard Replacement, Motherboard: passo 13, imagem 2 %32 Motorola Droid Motherboard Replacement, Motherboard: passo 13, imagem 3 %32
    • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
    • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
    Pergunte ao FixBot
    Comentar
  14. Motorola Droid Motherboard Replacement: passo 14, imagem 1 %32
    • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
    Pergunte ao FixBot
    Comentar
  15. Motorola Droid Motherboard Replacement: passo 15, imagem 1 %32
    • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
    Pergunte ao FixBot
    Comentar
  16. Motorola Droid Motherboard Replacement: passo 16, imagem 1 %32
    • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
    Pergunte ao FixBot
    Comentar
  17. Motorola Droid Motherboard Replacement: passo 17, imagem 1 %32
    • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
    • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
    Pergunte ao FixBot
    Comentar
  18. Motorola Droid Motherboard Replacement: passo 18, imagem 1 %32 Motorola Droid Motherboard Replacement: passo 18, imagem 2 %32
    • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
    • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
    • Remove the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Brett Hartt
Membro desde: 04/12/10
132.245 Reputação
Autoria de 144 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.230 guias
1Comentário do guia
Hi all,
Can anyone please suggest me should I dump my motorola droid. I have taken it to fix-it shops and they all have the same answer the mother board is gone
So, is it better to buy a new mother board which would cost me as much as a new phone or just sell it for nickels on Ebay
please reply pbansal1@jhu.edu
prateek - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 45
Ao todo: 29,657
