Ir para o conteúdo principal
Motorola Droid 4 Battery Replacement
O que você precisa
  1. Motorola Droid 4 Battery Replacement, Removing Rear Panel: passo 1, imagem 1 %32 Motorola Droid 4 Battery Replacement, Removing Rear Panel: passo 1, imagem 2 %32 Motorola Droid 4 Battery Replacement, Removing Rear Panel: passo 1, imagem 3 %32
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
    Pergunte ao FixBot
    Comentar
  2. Motorola Droid 4 Battery Replacement, Battery: passo 2, imagem 1 %32
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
    Pergunte ao FixBot
    Comentar
  3. Motorola Droid 4 Battery Replacement: passo 3, imagem 1 %32 Motorola Droid 4 Battery Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
    Pergunte ao FixBot
    Comentar
Conclusão
25 outras pessoas executaram este guia.
Gaetan
Membro desde: 12/26/12
9.613 Reputação
Autoria de 18 guias
17Comentários do guia
Jerk at the verizon store said this wasnt possible and tried to sell me a new phone, dumbass. Thanks for the guide!!
Rose M - Responder Compartilhar
Worked great ! Ordered battery fro Amazon and with Torx kit...5 minute job !
Peter Kendrick - Responder Compartilhar
Peter- I ordered a replacement and was able to change the battery. However, once in place, the phone would not boot up and would only show the battery icon with a question mark in it. Did you run in to this problem?
Ed Barton - Responder Compartilhar
The battery in my phone started swelling so I ordered a battery from Amazon. Changing the battery was easy, but now the battery icon has a red question mark in it. How do I reset the battery icon?
Tracy - Responder Compartilhar
Tracy -
I had the same problem.... Will be buying a new battery, torx screwdriver, and spludger tool and replacing the battery soon. Then I can use the phone as a backup device, or a second phone (new service needed for new line), in case my new Moto X dies....
Chris
Chris - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 75
Ao todo: 40,766
