Ir para o conteúdo principal
Motorola Defy XT SD Card Replacement
O que você precisa
  1. Motorola Defy XT SD Card Replacement, Battery: passo 1, imagem 1 %32
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    Pergunte ao FixBot
    Comentar
  2. Motorola Defy XT SD Card Replacement: passo 2, imagem 1 %32
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
    Pergunte ao FixBot
    Comentar
  3. Motorola Defy XT SD Card Replacement: passo 3, imagem 1 %32
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    Pergunte ao FixBot
    Comentar
  4. Motorola Defy XT SD Card Replacement, SD Card: passo 4, imagem 1 %32
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
    Pergunte ao FixBot
    Comentar
Conclusão
Dorian Capps
Membro desde: 04/19/13
64 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-22, Maness Spring 2013 Membro de Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Membros
Autoria de 12 guias
2Comentários do guia
I have replaced the SD card --32 GB---with smaller GB card-- and still my XT phone does not allow movement of APP to this card or saving photo files.
Any other suggestions to get phone to recognize the new card. Cant drag an APP (calculator, eg) to that memory card.
Must I format or seat the card ? or get a different brand ScanDisk 32?
Memorex 8 with Settings reads 7.2 GB total space on this smaller new card.
Gardner
Gardner Neely - Responder Compartilhar
thanks for any guidance on memory card problems Mounting/activating so that I can add files or APPS to that SD card on my Motorola Defy XT 2012 mobile phone.
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 23
Ao todo: 2,622
