Ir para o conteúdo principal
Motorola Defy XT Logic Board Replacement
O que você precisa
  1. Motorola Defy XT Logic Board Replacement, Logic Board: passo 1, imagem 1 %32
    • Wedge the opening tool in-between the back cover and the body of the phone in the opening denoted by the arrow.
    Pergunte ao FixBot
    Comentar
  2. Motorola Defy XT Logic Board Replacement: passo 2, imagem 1 %32
    • Once wedged in the opening, slide the opening tool around the side of the phone and remove the back cover, setting it aside.
    Pergunte ao FixBot
    Comentar
  3. Motorola Defy XT Logic Board Replacement: passo 3, imagem 1 %32
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    Pergunte ao FixBot
    Comentar
  4. Motorola Defy XT Logic Board Replacement: passo 4, imagem 1 %32
    • Open the plastic cover with your finger to expose the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
    Pergunte ao FixBot
    Comentar
  5. Motorola Defy XT Logic Board Replacement: passo 5, imagem 1 %32
    • Remove the six 6mm T4 screws with the T4 torque driver.
    Pergunte ao FixBot
    Comentar
  6. Motorola Defy XT Logic Board Replacement: passo 6, imagem 1 %32
    • Pop out the volume button with the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  7. Motorola Defy XT Logic Board Replacement: passo 7, imagem 1 %32 Motorola Defy XT Logic Board Replacement: passo 7, imagem 2 %32
    • Wedge the plastic opening tool in-between the plastic layer and the front cover.
    • Do not completely separate the two pieces to avoid damaging the ribbon cable inside.
    Pergunte ao FixBot
    Comentar
  8. Motorola Defy XT Logic Board Replacement: passo 8, imagem 1 %32
    • Carefully separate the bottom piece from the top plastic piece.
    • Disconnect the ribbon cable connecting the display to the logic board by firmly pulling the cable straight outward.
    • The screen can now be removed.
    Pergunte ao FixBot
    Comentar
  9. Motorola Defy XT Logic Board Replacement: passo 9, imagem 1 %32
    • Separate the logic board and the display cover from the back cover and orient the logic board so the camera faces toward you.
    • Disconnect the back cover by wedging the plastic opening tool in between the motherboard and the connector and prying outward.
    Pergunte ao FixBot
    Comentar
  10. Motorola Defy XT Logic Board Replacement: passo 10, imagem 1 %32
    • Flip the logic board and display cover over so the camera faces away from you.
    • Bend the two halves of the device away from you to pry the final ribbon connector off the logic board.
    • The ribbon connector is bonded to the logic board with adhesive, simply pull it to break the glue bond.
    Pergunte ao FixBot
    Comentar
Conclusão
No Name
Membro desde: 04/21/13
25 Reputação
Autoria de 1 guia
2Comentários do guia
Imbecells give up DEMONIC HOLD PRAISE THE LORD HE HAS COME 4 U
True Seminary - Responder Compartilhar
idoits have faith like a lil ole mustard seed
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 31
Ao todo: 1,704
