Ir para o conteúdo principal
Motorola Defy XT Battery Replacement
O que você precisa
  1. Motorola Defy XT Battery Replacement, Battery: passo 1, imagem 1 %32
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    Pergunte ao FixBot
    Comentar
  2. Motorola Defy XT Battery Replacement: passo 2, imagem 1 %32
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
    Pergunte ao FixBot
    Comentar
  3. Motorola Defy XT Battery Replacement: passo 3, imagem 1 %32
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    Pergunte ao FixBot
    Comentar
Conclusão
Dorian Capps
Membro desde: 04/19/13
64 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-22, Maness Spring 2013 Membro de Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Membros
Autoria de 12 guias
1Comentário do guia
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 2,149
