Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Moto G4 Midframe Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Moto G4 Midframe Replacement, Back Cover: passo 1, imagem 1 %32 Moto G4 Midframe Replacement, Back Cover: passo 1, imagem 2 %32 Moto G4 Midframe Replacement, Back Cover: passo 1, imagem 3 %32
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 Midframe Replacement: passo 2, imagem 1 %32 Moto G4 Midframe Replacement: passo 2, imagem 2 %32
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 Midframe Replacement: passo 3, imagem 1 %32 Moto G4 Midframe Replacement: passo 3, imagem 2 %32 Moto G4 Midframe Replacement: passo 3, imagem 3 %32
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 Midframe Replacement: passo 4, imagem 1 %32 Moto G4 Midframe Replacement: passo 4, imagem 2 %32
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 Midframe Replacement, Midframe: passo 5, imagem 1 %32 Moto G4 Midframe Replacement, Midframe: passo 5, imagem 2 %32 Moto G4 Midframe Replacement, Midframe: passo 5, imagem 3 %32
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 Midframe Replacement: passo 6, imagem 1 %32 Moto G4 Midframe Replacement: passo 6, imagem 2 %32
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 Midframe Replacement: passo 7, imagem 1 %32
    • Remove the rubber cover.
  8. Moto G4 Midframe Replacement: passo 8, imagem 1 %32 Moto G4 Midframe Replacement: passo 8, imagem 2 %32
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 Midframe Replacement: passo 9, imagem 1 %32
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  10. Moto G4 Midframe Replacement: passo 10, imagem 1 %32
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  11. Moto G4 Midframe Replacement: passo 11, imagem 1 %32
    • Remove the midframe.
Conclusão
Jeff Suovanen
Membro desde: 08/06/13
428.122 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 67
