Ir para o conteúdo principal
Moto C Plus Screen Assembly Replacement
O que você precisa
  1. Moto C Plus Screen Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Moto C Plus Screen Assembly Replacement, Back Cover: passo 1, imagem 2 %32 Moto C Plus Screen Assembly Replacement, Back Cover: passo 1, imagem 3 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
    • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
    Pergunte ao FixBot
    Comentar
  2. Moto C Plus Screen Assembly Replacement: passo 2, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 2, imagem 2 %32
    • Lift the phone out of the back cover.
    Pergunte ao FixBot
    Comentar
  3. Moto C Plus Screen Assembly Replacement, Battery: passo 3, imagem 1 %32 Moto C Plus Screen Assembly Replacement, Battery: passo 3, imagem 2 %32 Moto C Plus Screen Assembly Replacement, Battery: passo 3, imagem 3 %32
    • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
    • Lever the battery out of its recess and remove it.
    Pergunte ao FixBot
    Comentar
  4. Moto C Plus Screen Assembly Replacement, Daughterboard Cover: passo 4, imagem 1 %32
    • Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
    Pergunte ao FixBot
    Comentar
  5. Moto C Plus Screen Assembly Replacement: passo 5, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 5, imagem 2 %32 Moto C Plus Screen Assembly Replacement: passo 5, imagem 3 %32
    • Apply a spudger to the right side of the daughterboard cover.
    • Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
    • Remove the daughterboard cover.
    Pergunte ao FixBot
    Comentar
  6. Moto C Plus Screen Assembly Replacement, Motherboard Cover: passo 6, imagem 1 %32
    • Remove the five 3.1 mm long Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  7. Moto C Plus Screen Assembly Replacement: passo 7, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 7, imagem 2 %32 Moto C Plus Screen Assembly Replacement: passo 7, imagem 3 %32
    • Apply an opening pick to the bottom right corner of the motherboard cover.
    • Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
    Pergunte ao FixBot
    Comentar
  8. Moto C Plus Screen Assembly Replacement: passo 8, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 8, imagem 2 %32
    • Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
    • Pry up the motherboard cover until you can get a good grip.
    • Remove the motherboard cover.
    Pergunte ao FixBot
    Comentar
  9. Moto C Plus Screen Assembly Replacement, Motherboard Assembly: passo 9, imagem 1 %32
    • Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Moto C Plus Screen Assembly Replacement: passo 10, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 10, imagem 2 %32
    • Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
    Pergunte ao FixBot
    Comentar
  11. Moto C Plus Screen Assembly Replacement: passo 11, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 11, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
    • Fold the power and volume button flex cable out of the way.
    Pergunte ao FixBot
    Comentar
  12. Moto C Plus Screen Assembly Replacement: passo 12, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 12, imagem 2 %32
    • Pry up and disconnect the antenna cable.
    • Fold the antenna cable out of the way.
    Pergunte ao FixBot
    Comentar
  13. Moto C Plus Screen Assembly Replacement: passo 13, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 13, imagem 2 %32
    • Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
    • When reassembling make sure the white line on the cable aligns with the closed flap.
    Pergunte ao FixBot
    Comentar
  14. Moto C Plus Screen Assembly Replacement: passo 14, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 14, imagem 2 %32
    • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
    Pergunte ao FixBot
    Comentar
  15. Moto C Plus Screen Assembly Replacement: passo 15, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 15, imagem 2 %32
    • Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
    Pergunte ao FixBot
    Comentar
  16. Moto C Plus Screen Assembly Replacement: passo 16, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 16, imagem 2 %32
    • Use a pair of tweezers to pull the flex cable out of the ZIF connector.
    Pergunte ao FixBot
    Comentar
  17. Moto C Plus Screen Assembly Replacement: passo 17, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 17, imagem 2 %32
    • Don't try to remove the motherboard all the way yet. The display flex cable is still connected to its rear side.
    • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
    • Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
    Pergunte ao FixBot
    Comentar
  18. Moto C Plus Screen Assembly Replacement: passo 18, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 18, imagem 2 %32
    • Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  19. Moto C Plus Screen Assembly Replacement: passo 19, imagem 1 %32
    • Remove the motherboard.
    Pergunte ao FixBot
    Comentar
  20. Moto C Plus Screen Assembly Replacement, Daughterboard: passo 20, imagem 1 %32 Moto C Plus Screen Assembly Replacement, Daughterboard: passo 20, imagem 2 %32
    • Disconnect the antenna cable and fold it out of the way.
    Pergunte ao FixBot
    Comentar
  21. Moto C Plus Screen Assembly Replacement: passo 21, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 21, imagem 2 %32
    • Use the tip of a spudger to open the brown flap of the ZIF connector that holds the interconnect cable in its place.
    Pergunte ao FixBot
    Comentar
  22. Moto C Plus Screen Assembly Replacement: passo 22, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 22, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  23. Moto C Plus Screen Assembly Replacement: passo 23, imagem 1 %32
    • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
    Pergunte ao FixBot
    Comentar
  24. Moto C Plus Screen Assembly Replacement: passo 24, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 24, imagem 2 %32 Moto C Plus Screen Assembly Replacement: passo 24, imagem 3 %32
    • Apply an opening pick to the bottom edge of the daughterboard.
    • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
    • Take care to cut the adhesive underneath the vibration motor.
    • Slide the opening pick from right to left to cut all the adhesive.
    Pergunte ao FixBot
    Comentar
  25. Moto C Plus Screen Assembly Replacement: passo 25, imagem 1 %32
    • Remove the daughterboard including the soldered-on vibration motor.
    Pergunte ao FixBot
    Comentar
  26. Moto C Plus Screen Assembly Replacement, Earpiece Speaker: passo 26, imagem 1 %32
    • Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
    Pergunte ao FixBot
    Comentar
  27. Moto C Plus Screen Assembly Replacement: passo 27, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 27, imagem 2 %32
    • Use a pair of tweezers to carefully grab and remove the earpiece speaker.
    Pergunte ao FixBot
    Comentar
  28. Moto C Plus Screen Assembly Replacement, Screen Assembly: passo 28, imagem 1 %32 Moto C Plus Screen Assembly Replacement, Screen Assembly: passo 28, imagem 2 %32
    • Use a pair of tweezers to remove the rubber headphone jack gasket in the corner of the display assembly.
    Pergunte ao FixBot
    Comentar
  29. Moto C Plus Screen Assembly Replacement: passo 29, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 29, imagem 2 %32
    • Use a pair of tweezers to remove the rubber charging port gasket.
    Pergunte ao FixBot
    Comentar
  30. Moto C Plus Screen Assembly Replacement: passo 30, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 30, imagem 2 %32
    • Use a pair of tweezers to grab and remove the microphone rubber gasket at the bottom right end of your phone.
    Pergunte ao FixBot
    Comentar
  31. Moto C Plus Screen Assembly Replacement: passo 31, imagem 1 %32
    • Use an iOpener to loosen the adhesive tape that sits on top of the interconnect and display flex cable. Apply the iOpener on the tape for at least two minutes.
    Pergunte ao FixBot
    Comentar
  32. Moto C Plus Screen Assembly Replacement: passo 32, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 32, imagem 2 %32 Moto C Plus Screen Assembly Replacement: passo 32, imagem 3 %32
    • Use a pair of tweezers to gently peel the adhesive tape off the flex cables and fold it out of the way.
    Pergunte ao FixBot
    Comentar
  33. Moto C Plus Screen Assembly Replacement: passo 33, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 33, imagem 2 %32
    • Use a pair of tweezers to gently peel the product sticker off the interconnect cable.
    • In case you can't remove the sticker or it starts to rip apart you can re-apply an iOpener to loosen the adhesive.
    Pergunte ao FixBot
    Comentar
  34. Moto C Plus Screen Assembly Replacement: passo 34, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 34, imagem 2 %32
    • Use a pair of tweezers to grab and carefully peel up the interconnect flex cable.
    • Remove the interconnect flex cable.
    Pergunte ao FixBot
    Comentar
  35. Moto C Plus Screen Assembly Replacement: passo 35, imagem 1 %32 Moto C Plus Screen Assembly Replacement: passo 35, imagem 2 %32
    • Use a pair of tweezers to remove the antenna cable.
    Pergunte ao FixBot
    Comentar
  36. Moto C Plus Screen Assembly Replacement: passo 36, imagem 1 %32
    • Check your replacement part for any other components that need to be transferred before reassembly.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
260.696 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 27.554 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 29
Ao todo: 2,788
